Can NOT change my cut plane
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
7083 Aufrufe, 5 Antworten
Can change it on level two plan, but can not change it on level 1 plan
5 ANTWORTEN 5
Nachricht 2 von 6
Sahay_R
als Antwort auf: Anonymous
Can you edit the View Rage? Type in VR for that.
If you are not able to type in VR, that means that the view is controlled by a View Template. In the Properties palette, look for the View Template and edit it - you will be able to modify the View Range from there.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 6
als Antwort auf: Sahay_R
it was a little more complicated than that, I still can't do anything in that plan, but I was able to duplicate the plan and editing works, for the most part. However I am unable to delete the corrupted view
Nachricht 4 von 6
Sahay_R
Sounds like a pinned view.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Rina Sahay
Nachricht 5 von 6
Screenshot_1Screenshot_1I don't use any View Template.
How can I change my "Cut plane" into any already created one?
Tags (1)
Nachricht 6 von 6
You can't.  The Cut Plane is associated with the view's level.  Create a new view based on a different level.
