it is possible that a model in-place sweep can cut with void like wall reveal? or any suggestions? thanks
Why not use the Wall: Reveal tool? what are you trying to do?
Howard Munsell
Create In-Place Void and then before you close out of In-Place Modeling Session, use the Cut Geometry tool to cut the System Family Geometry with the Void.
Note: not everything will "cut". For instance, you can't cut Stairs or Loadable Families with In-Place Voids.
@barthbradley it is a model in-place sweep profile and cannot cut as you've mentioned or can you please show it to me how to do that. thanks
so you have a element that was modeled in place, and you want to place a void on it to represent something similar to a Reveal? unfortunately Reveals can only be placed on walls. edit your Model in place and add the needed voids/cuts.
in this example i made the in-place family a wall, but it can be anything...
Howard Munsell
