Can length of columns divided into parts be scheduled?
3 ANTWORTEN 3
Nachricht 1 von 4
blank...
238 Aufrufe, 3 Antworten
I have columns that go through the entire building, but now need to schedule them by level.
I divided all columns up into parts by Intersect by levels. For concrete ones I need volume by level which works fine, but for steel ones I need their length which I can't figure out how to get either through parts schedule/quantities or parts material takeoff.
Can this be done or do I just count how many per level and calculate it in Excel (levels are different height)?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: blank...
You can divide the volume by the area of the profile section (manually entered based on your column properties). However you can just make a column from one level to the next, then copy aligned to all other levels.
Nachricht 3 von 4
blank...
als Antwort auf: ToanDN
Of course, dividing into parts was just easier and faster to do. Excel it is.
Nachricht 4 von 4
Of course, until you need to create analytical model / calculation and steel connection.
