I saw a Youtube vid on creating a slightly sloped roof and using that for a work plane for a beam system. I assumed I could create a floor, (which I created to represent the deck sheathing) Then I sloped the floor. I created the beam system prior to creating the floor and I'm trying to change the work plane to the floor so it has a slope.
Unless someone has an easier way to model 2x8 deck joists presumably as a beam system, and the add a 1.5% slope to the deck.
I guess I should add that I keep selecting the beam system and selecting edit work plane, and pick new host. Neither is working. When I select an edge of the floor the beams orient vertically.
