Can I miter a top and side mullion within the seem curtain wall?
1 ANTWORT 1
Nachricht 1 von 2
269 Aufrufe, 1 Antwort
I'm trying to create a 'Fabric Wrapped Pane'l wall type for my firm. I wanted to do this using curtain walls. I created a custom mullion based on panel frame details we use. But I can't get top/bottom and left/right corners to miter or read correctly. Any ideas? See attached screen cap.
Tags (1)
1 ANTWORT 1
Nachricht 2 von 2
cyrankam
als Antwort auf: Anonymous
Unfortunatly there is no easy way to achive that with simple curtain wall.
If panels are only rectangular you could get away with creating custom panels witch mullions modeld inside the panel family. You will need different types, for corners and border panels, so it is pretty cumbersome. Other then that only adaptive components come to mind, but it seems like overkill.
