Can I make round corners in Revit Families with any Plug-in?
uoliveira
Message 1 of 8
uoliveira
Replies (7)
Message 2 of 8
You mean you need to fillet all squared edges?
Message 3 of 8
Sahay_R
You don't need a plug in.  When sketching in the Family Editor, you can fillet corners.
In situations where you can't sketch, use Voids to cut the fillets.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 4 of 8
uoliveira
hum ok, but about the family below, how can i make the encounter of planes in the oven's door be round? inventor has this tool, but Revit not..
Message 5 of 8
Sahay_R
Are you talking about the oven door? Can we try a box with rounded corners with a sweep going around it?
Rina Sahay
Message 6 of 8
I apologize in advance for the length of the following video but I wanted to give you a few techniques because trying to fillet edges in Revit isn't very friendly.  But it can be done if you know a few workarounds and rules to follow.
Revit 2017 - How to Radius or Fillet Edges - Not always Easy
Good Luck, you may need it!
Message 7 of 8
JJWGallagher
Is there any reason you're using Revit over Inventor? Typically with Revit you model what is required, then use detail items to fill in the little details. It seems like you're trying to use Revit as a 3d modeling program rather than a BIM program.
Message 8 of 8
Sahay_R
@JJWGallagher I can see the rationale - Inventor geometry once brought into Revit is 'dumb' geometry, cannot be controlled by parameters and types.
Rina Sahay
