Can I make changes to IFC file in revit?
5 ANTWORTEN 5
Nachricht 1 von 6
l.yong1
290 Aufrufe, 5 Antworten
Hi there,
Can I make changes to IFC file inside revit or  do I need to do it on another platform?
Please see IFC file screenshot here:
Thank you. Have a great day:lächelndes_Gesicht_mit_Sonnenbrille:
5 ANTWORTEN 5
Nachricht 2 von 6
bimscape
als Antwort auf: l.yong1
You will need to do it outside of Revit
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Nachricht 3 von 6
l.yong1
als Antwort auf: bimscape
Thank you for your reply. Can you please advice how do I do that?
Nachricht 4 von 6
bimscape
The starting point is..
What specifically do you need to do to the IFC file?
Kind regards,
Ian
Nachricht 5 von 6
l.yong1
I have exported 3D sketch up site model as IFC file so that I can import this into revit. Unfortunately I noticed I couldn't make any changes with the IFC file inside revit.
Nachricht 6 von 6
bimscape
Sound like you may be better Linking the IFC file. The you can make changes in Sketchup and re-export. Then your changes ill be refelcted when you next open Revit
Kind regards,
Ian
