Can I link system family constraint parameter to custom project parameter?
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
vladyslavr
202 Aufrufe, 1 Antwort
Hi there!
I am wondering, can I link specifically wall constraint base offset parameter to custom parameter? I want to add it in order to see this parameter of base offset in filters or for other purposes
1 ANTWORT 1
Nachricht 2 von 2
L.Maas
als Antwort auf: vladyslavr
I guess this became available in Revit 2023
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-2856AF63-6FCF-4FC5-8A64-51FBA497E877
Older Revit verison, you could do something with Dynamo. Basically copying the value of Base Offset to another/new parameter and use that for your filters.
Louis
Please mention Revit version, especially when uploading Revit files.
