Can I have access to the resource code of the wood framing add-in?
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
JLFN1964
710 Aufrufe, 13 Antworten
I would like to have access to the resource code of the Revit wood frame package add-in for a research purpose.
I am enroled in a Master engineering research which intends to develop a panelization automation for wood framing systems, at the University of São Paulo, Brazil.
The code will be probably written in Dynamo or even in Phyton or C#. My target is to link this new system into the Revit wood framing plugin.
Is it possible for me to have access to this code?
Thanks for now,
José Luis Fairbanks
Architect
13 ANTWORTEN 13
Nachricht 2 von 14
als Antwort auf: JLFN1964
You need to contact the author directly.
Nachricht 3 von 14
JLFN1964
als Antwort auf: ToanDN
OK. By the way, where can I find the author? Do you know?
Nachricht 4 von 14
Support Contact: rex.support@autodesk.com
Nachricht 5 von 14
JLFN1964
als Antwort auf: barthbradley
Thanks, but I´ve already written to this address, and it´s been discontinued.
Anyway, thanks a lot.
Nachricht 6 von 14
JLFN1964
I´ve tried contact at the e-mail provided, but it´s been discontinued. Is there any other way to contact the author?
Nachricht 7 von 14
Sahay_R
Appeal to a higher authority - try contacting @Viveka_CD.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 8 von 14
Viveka_CD
als Antwort auf: Sahay_R
Thanks for the alert @Sahay_R   (I'm just a helper...no way higher authorityLachender Smiley)
@JLFN1964 can you confirm if we are talking about the same plugin Timber Framing 2015
Let me get some more input from a dedicated resource.
Nachricht 9 von 14
JLFN1964
als Antwort auf: Viveka_CD
Yes, I refer to the Timber Frame 2015 for Revit.
Nachricht 10 von 14
Isn't this the intellectual property of Autodesk?
Nachricht 11 von 14
JLFN1964
Yes it is. I just wanna know if Autodesk would give me an access for academic research.
Nachricht 12 von 14
Viveka_CD
Hi @JLFN1964
I wanted to share the below feedback from the team:
Access to the source code is not possible.
As of now, this add-in (timber framing 2015) is not being updated and is part of the Revit extensions available via appstore.
Have you looked into other timber framing add-ins? (Check Strucoft, Agacad, hsbCAD)
@josemukalel can you provide input on timber framing?
Let me know if you have additional questions.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Tags (1)
Nachricht 13 von 14
JLFN1964
Thanks for the answer. I didn´t see it before.  Sorry! But that´s OK to me for now.
Nachricht 14 von 14
Viveka_CD
Hi @JLFN1964
Thanks for getting back to us and letting me know.
