I've been asked to export a model to .nwd. I have revit 2020 not navisworks.
From what i'm reading I would need navisworks to do this - am I correct?
Native revit can export only .nwc?
thanks!
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
no. you don't need to have navisworks to export (unless you want to open in navisworks?) just go to file ? export ? NWC , thats it. thanks
they can open NWC file in navisworks once they open they can saveas the file to NWD. thanks
thanks for the reply
It's to issue model to subcontractor. I'll pass this info to them
cheers, A
another way is to export TO NWC, then download navisworks trial version for 1 month . open in navisworks and saveas as NWD file then pass it your contractor. just saying thanks
