Can I export a 2021 revit file in a 2020 version?
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
6006 Aufrufe, 9 Antworten
Please help me I'm a new Revit user, and I'm learning with the 2021 version.
9 ANTWORTEN 9
Nachricht 2 von 10
martijn_pater
als Antwort auf: Anonymous
no
Nachricht 3 von 10
Backward Compatibility been a wish list item since the beginning of time. Someday maybe.
Nachricht 4 von 10
RobDraw
als Antwort auf: barthbradley
Not at the beginning but shortly thereafter.
Rob
Nachricht 5 von 10
Mohamed-Nassar
you can't do this with Revit, maybe in the future if autodesk allow us to downgrade models
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Nachricht 6 von 10
martijn_pater
als Antwort auf: Mohamed-Nassar
Don't hold your breath... :Gesicht_mit_rollenden_Augen: :Gesicht_mit_Geldzeichen-Mund:
Nachricht 7 von 10
RobDraw
Doubtful. The decision to not make Revit backwards compatible was made at the onset and for good reason.
Rob
Nachricht 8 von 10
Mohamed-Nassar
als Antwort auf: RobDraw
I am agree with you Sir but some times u need it in some cases, can you clarify the the reason, please
Nachricht 9 von 10
search this forum this has been discussed multiple times already
Nachricht 10 von 10
RobDraw
That's a question for the developers but the answer is not going to help you. If your projects are done properly, you should never need it.
Rob
