Can I display the Keynote Category or other additional info
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
AGGilliam
629 Aufrufe, 11 Antworten
My company is in the middle of transitioning from AutoCAD to Revit and I'm trying to determine the best way to display our notes on the sheets. Keynotes seems to be the best way to go but we have a sort of title/description in addition to the keynote text and I'm not sure if there's a good way to implement that.
(I apologize for the hard to read text)
Any thoughts or suggestions?
Beschriftungen (1)
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: AGGilliam
I would suggest Notes/Note Block.
https://www.youtube.com/watch?v=hK9caWfXSWk
Nachricht 3 von 12
Headers can be added through Schedule Formatting.
https://www.youtube.com/watch?v=8gtEEY0pJYM
Nachricht 4 von 12
AGGilliam
als Antwort auf: barthbradley
Thanks for the suggestion! That definitely seems closer to what we're looking for. Do you know of a good way to predefine notes that way though? I was thinking a key schedule might work but I didn't see Generic Annotations as an option.
Nachricht 5 von 12
Alfredo_Medina
Another common option for sorting general notes (or an abbreviations list) is a key schedule. It helps to keep the text in order, and you can sort the notes by number.
Nachricht 6 von 12
Doesn't that Video help? I would pretty much follow it verbatim.  Maybe add a 4th Text Parameter to enter the header title.
Nachricht 7 von 12
AGGilliam
als Antwort auf: Alfredo_Medina
How do I create a key schedule for Generic Annotations?
Nachricht 8 von 12
AGGilliam
The video shows how to create a schedule out of the notes in the project, but if someone needed to add a note to another sheet would they be able to directly place one without having to worry about defining the note text? That's why I was looking at a key schedule, so they can just select the note number and move on. If that's not an option that's fine but that wasn't addressed in the video.
Nachricht 9 von 12
SteveKStafford
If the notes in your example do not also include placing a symbol somewhere in the drawing that has the same number has your notes then many companies just use text to write out their general notes. If you also place a "keynote" next to elements in a drawing that reference the notes then as others have suggested the Noteblock approach is similar to an AutoCAD block w/ attributes.
The noteblock can carry the information you then schedule or it can just provide a way to enter number that matches the note's number. A Key Schedule can be used in conjunction with the latter.
Keynote tools, using a custom file, can produce a similar result as noteblocks and the notes are based on a text file of information that has to be edited to provide new notes, a more rigorous process that was designed with CSI designations in mind.
It's a matter of trying them and seeing which "poison" you prefer...
Steve Stafford
Nachricht 10 von 12
AGGilliam
als Antwort auf: SteveKStafford
We do call them out like keynotes, which is why I initially went with that approach but noteblocks seems to be the better way to go. Again though, I'm not seeing a way to create a Key Schedule for them. I'm using Revit 2022 if that makes a difference, is that a brand new feature?
Nachricht 11 von 12
SteveKStafford
No, noteblock and schedules are as old as dirt, the very first keynoting approach in Revit. A Noteblock schedule is really a schedule of the annotation family you place. When you create a schedule look for Noteblock Schedule in the list. Then choose the annotation family associated with your notes. For this to work the number and the description need to be in a unique type in the family. So you need a family that is the same as your number symbol next to the notes. Then a new type for each note with unique number and description parameters.
 A Key Schedule is a different animal, it is a schedule associated with a category like door (what it was originally created for...door hardware schedules). The add a number and description parameter to the schedule and then add rows until you've created all of them. There is no actual connection between the noteblock family (block w/ attributes) other than you choosing to provide the corresponding number. You have to keep after that if the schedule is changed and it affects the numbers you've already noted. This is "hack" of features to get a schedule of information that isn't directly tied to an element. As such the key schedules like this are usually assigned to a category you are not likely to really use or schedule elements for...like structural reinforcing...assuming you are doing architecture.
FWIW, I wrote this BLOG POST years ago describing these options...
Steve Stafford
Nachricht 12 von 12
AGGilliam
Took a step away for a bit and came back to mess with it some more. I think I got a bit of tunnel vision thinking of how to get a key schedule to work, but family types work just fine (go figure). I ended up going with @Anonymous 's original suggestion of using the noteblock and fiddled with the formatting to get something that actually looks similar to what we currently have. I'm not a huge fan of having a schedule for each sheet but I'll let the rest of the team weigh in.
The annotations can even be set to shared and placed in detail families rather than placing them in the drafting view, we'll just need to figure out how we want to filter the different schedules. Thanks for the suggestions and patience y'all, sometimes ya just need a little sleep haha.
