Can I copy a custom family parameters from one family to another?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
6431 Aufrufe, 2 Antworten
I created a whole bunch of custom family parameters in one family.
So as not to be redundant, how can I copy these exact parameters to other families?
2 ANTWORTEN 2
Nachricht 2 von 3
GHASEM_ARIYANI
als Antwort auf: Anonymous
Hello @Anonymous
Maybe solve the feature Shared Parameter
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 3 von 3
PrathapSekar
@Anonymous,
As I understand from your post you created family parameter if you want to share your parameters across the projects and families you have to create shared parameter file, to export your family parameters to shared parameter go through THIS...
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
