can i convert voild sweep to sweep in revit
3 ANTWORTEN 3
Nachricht 1 von 4
mariaUXCWG
216 Aufrufe, 3 Antworten
I created a void sweep but realized that it would work better as a sweep (no void) can i convert voild sweep to sweep in revit
3 ANTWORTEN 3
Nachricht 2 von 4
syman2000
als Antwort auf: mariaUXCWG
Yes. Select the sweep and swap it with Solid
Nachricht 3 von 4
mariaUXCWG
als Antwort auf: syman2000
I am not seeing that as an options.  Am i missing something? I did notice that i have the option to change the extrusion but i dont have the option for void sweep.
Nachricht 4 von 4
syman2000
If the sweep void already cut into the existing solid, you have to use the uncut geometry. Once you done that, you should see the option to switch from void to solid.
