Can I change line weight of view crop?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
azusaa
2503 Aufrufe, 4 Antworten
In our office, we supposed to have interior elevation view's boundary (view crop line) to be thick, line weight of 6.
We have been accomplishing this by
  • Moving the boundary (crop line) close to the wall edge, so that wall section line shows thicker
  • Or overriding the boundary per view.
It would be very handy if we can set the crop line weight to 6, so that we don't have to override each view. But I have not found a way to do this.
Does anyone know how to do this?
Please advise. Thank you!
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: azusaa
@azusaa
For now you have to work with Override By Element...Those have no category so not accessible through OS or VG.
Alternative could be Dynamo OR post a Revit Idea HERE see if it gets votes enough for Autodesk to implement
Nachricht 3 von 5
azusaa
als Antwort auf: RDAOU
Okay. That's what I thought... Thank you for reply!
Nachricht 4 von 5
respresso
The most popular practice I saw is to put a donut-shaped (with a hole in the center) masking region on the view and select a suitable line style for the internal loop. Then the line weights can be set to that line style to update it for the whole project.
Nachricht 5 von 5
azusaa
als Antwort auf: respresso
Yes, we tried that too. Thank you for reply though :leicht_lächelndes_Gesicht:
