I want to change where revit automatically selects to place the dimension lines, instead of in the center of the wall to pick the side of it automatically. I know industry standard is center of wall, but with my workplace they would rather have it on either side. Is this possible so I don't have to click tab with every single placed dimension?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Change them all after the fact? No. You'll need to redo them. Use your TAB Key to select the face of the walls.
...this may help you as well:
Help | Specify Temporary Dimension Settings | Autodesk
Temporary Dims can be converted to Permanent Dims.
