Can I access Revit 2018 file in Revit 2017?
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
1595 Aufrufe, 5 Antworten
I saved a project in the 2018 version of Revit. I am wanting to know if there is a way for me to access the file in the 2017 version of Revit.
Title edited for clarity by @Viveka_CD
New title: Can I access Revit 2018 file in Revit 2017?
5 ANTWORTEN 5
Nachricht 2 von 6
jordan.giboney
als Antwort auf: Anonymous
Hi @Anonymous
Thanks for posting! This forum is for Autodesk Maya, rather than Revit :leicht_lächelndes_Gesicht: For the best response, I would recommend posting on the Revit Forum which can be found here: Revit Architecture Forum
Hope that helps! Thanks again for being a part of our community! :leicht_lächelndes_Gesicht:
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Nachricht 3 von 6
Revit is not backward compatible.  If it is a must, you could open teh file in 2018, export to IFC, tehn open the IFC in 2017.  Be prepared for the lost of editability for a host of things if you choose to do it that way.
New title: Can I access Revit 2018 in Revit 2017?
Nachricht 4 von 6
Viveka_CD
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Please see similar thread and solution HERE
Let me know if you have any questions.
Nachricht 5 von 6
als Antwort auf: ToanDN
sorry for so many replies but this is for a school project that i am trying to work on at home. but at home i have Revit 2018 and i need Revit 2017 so i can work on it at home and at school. sooo is there any way for me to downgrade the product Revit 2018 to Revit 2017. also if you read my other message first please disregard it.
Nachricht 6 von 6
Viveka_CD
Hi @Anonymous
No you cannot downgrade.
Please see recommendation by @ToanDN and my previous post for related article and solution.
Let me know if you have questions on these recommendations.
Good luck with your project!
