Can color schemes mask model elements like a filled region?
3 ANTWORTEN 3
Nachricht 1 von 4
roedigerF6NSW
215 Aufrufe, 3 Antworten
I have a section which is using a color scheme based on rooms and we would like to mask the model elements shown within the rooms. Although color scheme location is set to foreground, the color fill is not masking model elements. Is this possible to achieve or will this only work with filled regions? Is there an alternative solution to make the section appear as just a series of color blocks? Thanks
3 ANTWORTEN 3
Nachricht 2 von 4
vitorbortoncello
als Antwort auf: roedigerF6NSW
Color schemes in Revit do not mask model elements like filled regions do, even when set to the foreground
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 4
What about just reducing the Far Clip Distance?  In other words, not including the background Model Elements within the View Range.
Nachricht 4 von 4
handjonathan
als Antwort auf: barthbradley
Hi @roedigerF6NSW
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @vitorbortoncello @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
