Can a Revit Parameter use a "String" command in a formula?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
graeme.mairHXEAM
766 Aufrufe, 2 Antworten
In ArchiCAD you can create a parameter that uses another parameter to extract information from that parameter.
Is it possible to do the same in Revit?
So for example you can have a parameter that is a piece of text that describes a Keynote "10 Facing Brick".  You can then have another prameter extract just the last word or the first digits in the sentence and then display that instead.
Tia
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
Nope, unfortunately Revit does not have this feature.
All kinds of string manipulation require workarounds with Dynamo or plug-ins.
Nachricht 3 von 3
Ah, thats a shame. I was hoping to avoid having to use Dynamo.
Thanks for your answer.
