Can a Curtain Panel have a Type Image?
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
curtisridenour
442 Aufrufe, 9 Antworten
I cannot seem to edit the Type Image parameter for a curtain panel family.
I can edit the Image parameter but not the Type Image one. Any insight on the matter would be appreciated.
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: curtisridenour
You can add Type Image to Custom panel families. Or you can use a basic wall type for curtain panels and assign type image to the wall type.
You can add a new image type parameter to Curtain Panel category.
Nachricht 3 von 10
curtisridenour
So that is a negative for the normal curtain panels?
Nachricht 4 von 10
vitorbortoncello
No, a Curtain Panel in Revit cannot have a Type Image parameter. However, you can use the URL parameter to link to an external image if needed
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 5 von 10
curtisridenour
Thank you. Good to know. We will probably use the instance Image parameter sadly.
Nachricht 6 von 10
A Curtain Panel CAN have an Image Type Parameter.
Nachricht 7 von 10
curtisridenour
als Antwort auf: barthbradley
Yes a project/shared parameter would allow for that. But the OOTB "Type Image" parameter I don't think can be used.
Nachricht 8 von 10
Nachricht 9 von 10
vitorbortoncello
This solution will only work in Revit Full, not in Revit LT
Nachricht 10 von 10
curtisridenour
I was specifically looking to use the OOTB parameter Type Image. We already use this parameter for most of our schedules. I was very confused why I could not use the same parameter for a Curtain Panel Schedule. I am sure Autodesk has their reason but it seemed really odd that I could not. I was hoping it was not just User Error on my part. I was seeking confirmation of my assumption. Vito provided that confirmation.
