Camera is stuck, locked in position, can not use or move it. Please help !
I wanted to use camera for 3D view of my project details and something happened - it stuck in one place and I can not move it, can delete it, but when click on camera to open it again it appears in the same place stuck - locked in there. I can not use it anymore at all, can not move it either. Please help ! Thank you !
Accepted solutions (3)
I've had that happen before. Just create another camera view and try not to piss Revit off this time.
aRcHiTeCt.JM
... hi @Anonymous
... you have locked views
... to unlock them
... go to unlock 3d view
... and / or go to your 3d view
... click the surrounding square
... and unpin the pin
... or as @barthbradley  said:
... delete the 3d view and create a new one
... fast and easy way
.... *** but if what you are saying is that the 3d view box is grey out when trying to open it
... then to be able to use that.... you need to be in a floor plan
... not in a 3d view
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Thank you !!! It is back !
Thank you ! It is back !
My solution simply duplicate the plan and then work in the new one.
Cheer
Chatton32
Community Visitor
Community Visitor
my 3D camera view at the bottom is not locked and does not give me an option to unlock. So, that route did not work for me. In addition, even when i delete all my 3D images, the camera still shows as Frozen. please help. thank you
