Callout that references a view in a legend
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
rgbutzarchinc
3331 Aufrufe, 3 Antworten
I have a site plan populated with families, i.e. a dumpster family. I have created a legend with the dumplster floor plan, North elevation, and an East elevation.  How can I reference the site plan callout to the dumplster ledend.
Or how can I label each of the 3 dumpster family view and have the site plan call out reference, in this case the dumpster floor plan.
3 ANTWORTEN 3
Nachricht 2 von 4
cbcarch
als Antwort auf: rgbutzarchinc
Instead of using Legend Views,
Why not just create an Enlarged Plan of the typical Dumpster, add your Elevations, and make a Sheet and place all the Views on it.  Then on the Site Plan, use a Callout to reference the Enlarged Plan, which will take you to the Sheet.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 4
You cannot reference Legend (and Assembly views) with Callout, Elevation, Section tags.  The only way for now is using a View Reference with a built-in or manually drawn graphic for for callout/section/elevation symbols.
Nachricht 4 von 4
scadetMH3VD
