Callout heads
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
yes_and_no
194 Aufrufe, 1 Antwort
Callout heads
I ve been able to have two different callouts refer to the same detail, attached.
I wonder if there is a way to make a y/n or something to letter "A", so I can switch A to B, but both call-outs will stay A and B, (not default to either A or B).
You know in our details, we often have smaller sub-details. This is for that.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: yes_and_no
No.  Instance parameters do not work in callouts.  You need different callout types but one view can only be associated with one callout type.
Use text for A or B manually.
