We are trying to insert tables referring to min. required Glazing/Opening sizes for each room in a project.
The calculation is simple as it is going to be the Room Area divided by either 10/15/20.
Can anyone suggest the best way about creating such table? I have looked at creation of a room shared parameter, but I was only able to do so with an instance parameter which does not allow for reference of other parameters (can't do "=Area/2" .
Gelöst! Gehe zur Lösung
Gelöst von ralphdenhaan. Gehe zur Lösung
Just in case the above wasn't clear, we are trying to basically get a table similar to the attached one.
You can create a calculated formula like this?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
