Calculation Failed
2 ANTWORTEN 2
Nachricht 1 von 3
972 Aufrufe, 2 Antworten
Calculation Failed
When I try to do "Collor fill legend" in my Revit 2018, the revit show me an erro "Calculation Failed".
2 ANTWORTEN 2
Nachricht 2 von 3
Avaris.
als Antwort auf: Anonymous
It is a known problem and in general resolved in updates of that particular version. Do you have the latest 2018 version?
Otherwise, try this:
  1. Open all of the views in which the color fill legend shows "Calculation Failed."
  2. In any one of those views, select the color fill legend.
  3. In the ribbon, click Edit Scheme.
  4. In the Edit Color Scheme dialog box, in the drop-down menu that is labeled "Color:", choose any option other than the currently chosen option.
  5. Click OK to dismiss the "Colors are not preserved..." warning.
  6. Click Cancel to close the Edit Color Scheme dialog box. (Because you clicked Cancel, the legends will not be reconfigured for the different option that you chose in Step 4, but the legends will be re-created without the "Calculation Failed" message.)
Nachricht 3 von 3
als Antwort auf: Avaris.
Thank you, but.
I already did try this but I didn't got. When I open my file in the another computer, your solution is ok, but in the my computer no.
I did reinstall the all autodesk products but I didn't got yet.
