What Calculated value formulas would I need for the below -
Wattage per m²
Allowable wattage / Room
Installed wattage m²
Link copied
Wattage per m²
Lighting Fixture Schedule that pulls in Room Properties
That's where I would start.
i need to create a schedule that -
1. Takes in the Room area,
2. Multiplies the light fittings placed (wattage per fitting) within a room area.
3. Calculates the maximum wattage allowable for that room. (5w per m²).
4. Yes or No Complies
Not sure if Room Schedule or Light Fitting schedule works best ???
You want to use a Space Schedule. This should give you everything you need. Create one and let me else you need. Be happy to help.
Adding the Spaces Shedule is not allowing any wattage calculation -
1- Filter List – Architecture & Electrical
2 - From Rooms
3 - Adding Maybe Actual Lighting Load per area - no wattage fields available
Wanting a schedule like this -
Did you create a Space Schedule @Tinman1975? If not, create one and include every single Parameter Field that is available. View the resulting Schedule. See any columns that are empty of values? Delete those Parameter Fields from the Schedule. Post a screenshot the resulting Schedule.
@barthbradley yes Mate.. didn't give me the fields i thought would have worked (Lights)
@barthbradley the below image is what im aiming for based of a lighting plan layout..
A Space Schedule???
@barthbradley what field do you suggest i enter ?
Do what I asked in Message 10.
Dude! You're killing me here! I just want to see a screenshot of the actual Space Schedule - excluding any extraneous columns of non-information.
@Tinman1975 wrote:Nothing coming up
Okay, I guess I should have covered this up front. My bad (I guess). You first need to create Spaces from those Rooms. You got Rooms; right?
