calculated schedule parameter in annotation tag
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
andy.van.slambrouck
454 Aufrufe, 5 Antworten
Hi all,
I have a window schedule where I have created a calculated parameter. Now I was wondering if it's possible to use the result of that calculated parameter in a window tag. I cannot find or refer to that parameter when editing a new label in the window tag family.
Regards
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: andy.van.slambrouck
You can add the same Calculated parameter to a Label in the tag (2017 and up).
Nachricht 3 von 6
als Antwort auf: ToanDN
Huh???
Nachricht 4 von 6
andy.van.slambrouck
Thx for the reply. But I'm afraid it will not work in my case. The calculated parameter from my schedule is the result from another calculated parameter. And in the first calculated parameter I refer to a room parameter what is possible in a window schedule. But in the window tag I cannot refer to room parameters I think?
Nachricht 5 von 6
For cross category calculated parameters you have to use Dynamo, unfortunately.
Nachricht 6 von 6
