Calculate wall quantities, while ignoring openings less than 2.5 m2 ???
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
904 Aufrufe, 4 Antworten
The rule in Germany is that any opening less than 2.5 m2 must be ignored in quantities calculations for walls,
is there a way to automate that?
Thanks!
4 ANTWORTEN 4
Nachricht 2 von 5
martijn_pater
als Antwort auf: Anonymous
Just thinking here, but perhaps you could create a (last) phase in the project and demolish wall openings smaller then 2.5m2 in this phase and have Revit calculate the wall there including the infill walls? What type of opening btw?
Nachricht 3 von 5
RDAOU
@Anonymous
You can do it using dynamo...but if you are not into dynamo, there an application on Autodesk App Store for Revit called "Wall Opening Area Measurement" which I think does what you are asking for (not sure if they have a 2020 version though)
https://apps.autodesk.com/RVT/en/Detail/Index?id=6956732096827902056&appLang=en&os=Win64
Nachricht 4 von 5
RDAOU
@Anonymous
Du kannst Gebäudebuch probieren…Ich glaube es tut genau das wo du nachgefragt hast…und pass auf das du auf die deutschen (VOB Standard) Aufstellungen wechselst
Nachricht 5 von 5
als Antwort auf: RDAOU
Danke @RDAOU ! yup, dass ist gennau was ich gesucht habe!
Grüß
