Calculate only the width of walls' structure without finish layers
1 ANTWORT 1
Nachricht 1 von 2
232 Aufrufe, 1 Antwort
Hi!
I am preparing the schedule of the wall areas. However, I would like to use only the width of structure - without the finish leyers. Then multiply it by the lenght.
I can use a calculated parameter (width - "finish") but I am looking for the general solution.
Have you already solved that problem?
Thank you for your help!
1 ANTWORT 1
Nachricht 2 von 2
amorap
als Antwort auf: Anonymous
Hi from Spain rodzenpaulina.
Usually to do this, I use "computo de materiales de muro" (I suppose that in english version of Revit  would be wall materials schedule or so), not the object or quantity schedules.
In this type of schedule, you can select more information related to each material in a wall, and then apply filters by material in order to display only the ones you need.
Regards.
Augusto Mora
Architect & teacher of Building Projects at CPIFP Pirámide. Huesca (Spain).
Revit 2014 certified profesional.
