Calculate Cut Footprint in Schedule
2 ANTWORTEN 2
Nachricht 1 von 3
nick.atwell5H5BS
156 Aufrufe, 2 Antworten
I have generic model families that are basic square extrusions. Sometimes these families overlap others in the same location. If I cut the geometry, is there a way to schedule the cut footprint for each block, so that I am not double counting total area? I figured out a way to do it using a volume parameter that shows total volume not cut (divided by height), but if the blocks aren't the same height, I don't get the desired result.
Thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: nick.atwell5H5BS
Join geometry then create parts and schedule parts for material takeoff.
Nachricht 3 von 3
Is this what you are after?
