Calculate construction volume
10 REPLIES 10
Message 1 of 11
coolenyoshi
779 Views, 10 Replies
How can I calculate my building volume with Revit LT?
PS: Mass in place is not available in Revit LT.
Labels (5)
10 REPLIES 10
Message 2 of 11
in reply to: coolenyoshi
Create a room or space bounding by the exterior walls and roof. Set room computations to area+volume.
Message 3 of 11
coolenyoshi
in reply to: ToanDN
Thank you for your suggestion. However, what do you mean by 'space bounding'? Excuse me my revit knowledge is limited.
Message 4 of 11
coolenyoshi
in reply to: ToanDN
Analyze tab is also not avaible in Revit LT.
Message 5 of 11
Just use room then.
  • Set room computations to area + volum
  • Create one exterior phase and one interior phase
  • Move exterior walls and roofs to exterior phase
  • Add a room under exterior phase, set limit offset to above the highest point of the building then you have a room with the volume of the building
Message 6 of 11
coolenyoshi
in reply to: ToanDN
Does this method also work for complicated shapes?
Message 7 of 11
What about just totaling Volumes in Schedule?
BTW: You could get there by tracing the exterior face of exterior walls with Room Separation Lines and creating rooms bounded by these Room Separation Lines. You would do this in a Phase BEFORE construction with View Phase Filter set to "none". Room Separation Lines have Phase Created/Phase Demo'ed just like Walls, Floors, etc. So, you would demo them in the subsequent Phase where the construction begins.
Message 8 of 11
HVAC-Novice
You need to define what volume you need and for what purpose. Some possibilities:
- total volume to determine if a professional has to stamp the design : this would include the total volume measured from outside of enclosure and includes volumes of walls, floors (it isn't just the actual room volume)
- volume of rooms only (this would exclude volume of walls etc. and the above mentioned room schedule should work)
- include or exclude plenum and other intentional voids like shafts in a building?
Without knowing what volume you need and for what, it is hard to answer how to get the correct number. Same goes for area calculations where walls and void spaces could be included or excluded.
Edit: there seems to be a website issue preventing me to have space between paragraphs
Revit version: R2025.2
Message 9 of 11
coolenyoshi
in reply to: ToanDN
Thank you for your contribution. However, I am looking for the volume with exterior walls and roof included.
Message 10 of 11
coolenyoshi
in reply to: HVAC-Novice
I need the total volume so that the official can approve the project. This include the total volume measured from the outside. Including volumes of walls, floors and the actual rooms.
Message 11 of 11
Then get them from wall/roof schedule and add them to the result of the room volume to get the total volume.
