Hello all,
I am using the Revit 2018.2. When I go to Export Model from Revit to CADtoEarth the Revit stuck and it doesn't work.
Do you have to provide me any solution?
Thank you in advance!
Hi @mairh_tsek
Can you share a screencast of what you are experiencing?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
This is what I am taking when I go to Google Earth (Attachment 1)
This is what I would like (Attachment 2)
That's what I'm talking about as well -- and as per the Link I posted. The old way is no longer supported. You need to use Celsium -- available through its own tab on the interface. Get it? It's easy breezy.
