CAD import
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
jfjacques
827 Aufrufe, 5 Antworten
CAD import
Trying to import a cad file.
Moved UCS origin in CAD to the middle of the pile of drawings.
When I import nothing shows up.
I get the following warnings.
5 ANTWORTEN 5
Nachricht 2 von 6
GustavoUbriaco
als Antwort auf: jfjacques
Hi! what happens if you change center to center in the import dialog box?
Gustavo Ubriaco Contreras
Nachricht 3 von 6
syman2000
Revit doesn't read UCS in the drawing. Revit only accept WCS. So you have to physically move the entire drawing to 0,0 in AutoCAD or you set the CAD link as center to center instead of origin to origin.
Nachricht 4 von 6
jfjacques
als Antwort auf: syman2000
Center to center doesn't have any impact.
I had to move the cad file to its WCS origin as suggested.  No idea what UCS vs WCS is analogous to in Revit - project vs Survey?
Now the issue is that it imports like below. Essentially missing half the walls, what's going on? Is there a better way of getting things from revit to CAD?
Nachricht 5 von 6
syman2000
Upload the file so we can take a look.
Nachricht 6 von 6
jfjacques
Needed to explode everything and purge.
Oh autocad... you anachronic piece of ****.
