CAD-File with too much Text slows Revit project
21 ANTWORTEN 21
Nachricht 1 von 22
albano.haruni
1654 Aufrufe, 21 Antworten
this is my first question in this forum, I hope I get lucky.
We have a infrastructure project for which the Structural Part is done in Revit. We get some CAD-Files which we use as references for modelling. When we link a CAD our Revit project becomes very slow. Zooming in and out takes 4 Minutes. I starting breaking the CAD file down to the origin elements in AutoCAD and I believe that having a CAD with too many Text in it causes the problem.
If I take all TEXT from CAD away, there is absolutely no delay when zooming in and out.
In order to solve this problem, I have already tried many ways but nothing works.
  • In ACAD we use txt.shx which Revit should convert into Arial.
  • Converting Text into Polylines can not be done automatically with txtexp or t2g.
  • Splitting Geometry from Text and Import + Explode for Text would work but not being able to import by shared coordinates makes it impossible.
  • Exporting the CAD file into IFC/NWC/DWF/SHP/Civil 3D Drawing is also not successful.
  • Creating Blocks from Text in ACAD doesn't solve it.
  • .... and a bunch of other workarounds which I can not remember right now
Attached is a simple CAD-File with more than 400 Text for anybody to test.
Can anybody help me?
21 ANTWORTEN 21
Nachricht 2 von 22
cbcarch
als Antwort auf: albano.haruni
-I doubt that the text is causing slow down in Revit.
-Try Purging the Cad file. Delete anything out of it that you don't need in Revit.
-Check where the Origin of the Cad file is--in relationship to Revit's internal origin, Project Base Point and/or Survey Point. If the Cad file's origin is more tan 20 miles away, Revit will have problems.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 22
albano.haruni
als Antwort auf: cbcarch
I did purge but that doesn't help. Positioning of the CAD File is not causing the problem as well - I am not getting any warning. Loading it into a blank project with the option center to center is also slowing it down.
Please feel free to try the attached CAD-File or create one with a lot of Text and try to navigate in it in revit.
Nachricht 4 von 22
Instead of keeping all the text as SHX, change them to a TTF so Revit doesn't have to convert.
But in the long run I suggest ditching this process and keep everything in Revit.
Nachricht 5 von 22
albano.haruni
als Antwort auf: Anonymous
That doesn't work
Nachricht 6 von 22
Are you inserting the CAD file into the project or Linking "By View" only?  Also, how many CAD files are you inserting into the project?  Revit isn't Autocad....while you can link in a few DWG's for references, it doesn't like a bunch of them as you are finding out.
Nachricht 7 von 22
albano.haruni
Problem exists also with just one CAD
Nachricht 8 von 22
One file? Have you tried Auditing?
Nachricht 9 von 22
albano.haruni
als Antwort auf: barthbradley
No, what is Auditing? Yes, one file. Feel free to try yourself.
Nachricht 10 von 22
Another possible issue...your workstation is underpowered.  What are your specs?
Nachricht 11 von 22
Depends on where you Audit? In Revit, open file with "Audit" box checked. In AutoCAD, type "Audit".
Are you saying this is the problem-child in your Revit Project? "test, test, test, test, test...."?  Serious?
Nachricht 12 von 22
albano.haruni
Everything Else Works Perfect. Which specification do you exactly have in mind?
Did any of you tried this out and can confirm or reject my issue??
Nachricht 13 von 22
albano.haruni
I have already done purge, see above
Nachricht 14 von 22
BTW: I had no issues with your example CAD in Revit.  Just a thought: are you sure it's inserting at the proper units in your Revit file?
Nachricht 15 von 22
Computer specs....Processor, RAM, hard drive, video card, etc...
Nachricht 16 von 22
albano.haruni
I will Check that tomorrow. Thank you!
Nachricht 17 von 22
dplumb_BWBR
Open the file in CAD
Freeze the layers with text on them
Save
Link into Revit & pick "Visible" from the Layers/Levels drop-down
Nachricht 18 von 22
albano.haruni
als Antwort auf: dplumb_BWBR
That sounds interesting. I will try that tomorrow and let you know. Thank you!
Nachricht 19 von 22
albano.haruni
That makes my text invisible which is unsatisfying.
Nachricht 20 von 22
albano.haruni
Yes, Meters in both ACAD and Revit. That is odd that you don't have this issue when you try...
