Cad Export Layer Settings - Wall Cut Pattern
dilistan.bozan
dilistan.bozan
I have two different wall types with two different hatch in revit model. I want to assign different cut pattern layer for these wall types in cad export settings but as i understood it is not possible. Do you know any method ? thank you.
David_W_Koch
There is no way to assign different cut patterns to Wall layers via the CAD Export settings.  You can put Cut Patterns on a separate layer, but you cannot change the pattern.
Do you have the desired patterns available in Revit?  If so, you could set up a View just for exporting, and override the cut patterns you use for Revit and substitute the ones you want to see in CAD.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
