The cable trays aren't connecting no matter what angle I try to connect them and I am presented with the following error message in the image attached despite loading all the cable tray connectors.
At first I thought the angles were perhaps too much for the software to automatically connect but after trying a simple 90 degree connection It still didn't work.
Any help would be much appreciated
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Thanks for getting back to me.
I drew them in plan and want them on the same level?
I'm not sure what you mean by askewed...
The error says it all: you need to load fitting families and assign them to the system. To get them quickly: Create a new project using System-Default project template and transfer project standards from it to yours (check all cable tray boxes).
Thanks.
I had them loaded already which is why I was confused but I didn't know I had to assign them to the tray
