Hi everyone,
I have created a full cabinet with swing door. everything was okay until I changed the door angle to 90 degree. after that each time I change the door angle to anything less than 90 it shifts the whole door to the left. basically each time time I change it to 90 and then something less than that, door shifts to the left!
Please see attached file!
Thank you
Gelöst! Gehe zur Lösung
Looks like your swing reference line was not constrained properly to a reference plane.
Suggest hiding everything but your reference lines and planes and dimensions and move your reference line out and move back using the endpoint of the line to the intersecting reference planes. Click TAB to make sure you get the correct snap location.
