Good afternoon,
I'm trying to create cabinet details/panel details in Revit, AFTER I have my design laid out so my shop or a fabrication shop can follow my detail drawings.
I'm trying to find the most efficient way in Revit to utilize this without recreating the wheel every time.
I have a cabinet with a shelving unit I created out of wall above (made plywood material as a test design), (see all pics for better explanation), with arch cut out, etc.
I want to bring it in to either "Drafting View" or "Legend", I have to redraw it in "Drafting View" which I don't want to do....if I bring it into Legend the Cabinet allows me to select the views, BUT the wall doesn't allow me to select elevation view. This design needs to have the pieces broken down so the fabrication shop and cut and assemble.
Any ideas?
@brianwclayton1969 wrote:...if I bring it into Legend the Cabinet allows me to select the views, BUT the wall doesn't allow me to select elevation view.
Isn't the elevation of a wall just a rectangle?
Thanks for the input, see the attached pic. This is what I'm trying to go for in the Legend of Revit for a wall, without recreating the wheel. Sort of like the side panel of a cabinet detail where I can show the components. But you cannot bring in a wall and make the elevation in a Legend view or a Drafting view I don't want to have to redraw the wall every time.
This will allow me to drag and drop the details to a detail sheet.
