c3a error
4 ANTWORTEN 4
Nachricht 1 von 5
432 Aufrufe, 4 Antworten
c3a error
I'm having an error when I start revit 2017.
Using Windows 10.
This is a problem because I need this for my schoolwork.
Please check my images i've add to this post.
Kind regards,
Tibbe V.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
From your screenshot, you're not looking in the same directory as Revit is looking.
Nachricht 3 von 5
ennujozlagam
@Anonymous hello, Try to uninstall and reinstall the program, don't install any third party add-in and see if there are any issue. Thanks
Nachricht 4 von 5
Before you go uninstalling and reinstalling....go to that directory where that dll is...select, right click, select propeties.  Check to see if there is a Security message at the bottom of the General Tab and select the button next to it so it enables the DLL..
disclaimer:....if your system gets hosed, I am not at fault...blame where you got that C3Admin addin from.
Nachricht 5 von 5
Kimtaurus
Ik denk dat je best C3A contacteerd. Zij kunnen je via de telefoon verder helpen of via Teamviewer.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
