Bullzip PDF not printing entire page
2 ANTWORTEN 2
Nachricht 1 von 3
biztrobill
437 Aufrufe, 2 Antworten
Hi all.
I've been using Bullzip for a couple of years to print 24x36 multi-page PDFs from Revit LT. But when I recently updated Revit LT to v2023, I'm getting odd results from Bullzip. For example, today I printed a 7-page document, 24x36. The first 2 pages are fine, but the last 5 pages only printed the middle portion. The printed linework is to the proper scale (not shrunk to fit) but the outer +/- 25% of width and height is not printing. So it's printing only the center 12x18 of the 24x36 sheets. See screenshot.
Printing just one of the affected sheets, alone, prints perfectly.
Any clues? Is it Revit or does Bullzip need an update? Any help would be greatly appreciated.
Bill Fowler NCARB
Revit LT Suite 2024
Mac M2 Pro Mini, Apple Studio Display; w/ macOS Ventura, Parallels 18, Windows 11. 32GB memory (Parallels assigns 16GB for Windows virtual machine)
Solo Architecture practice in residential and small commercial design.
Tags (3)
2 ANTWORTEN 2
Nachricht 2 von 3
L.Maas
als Antwort auf: biztrobill
Could be Revit 2023. It is just released so could have some bugs. I have not used 2023, I usually wait few months before starting to work with the new version.
Some things you can try:
-Check your print settings
-Try another PDF printer
-Instead of the PDF printer try the  export pdf function in Revit (not sure if available in LT)
-Try it on another computer
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 3
Corsten.Au
Just one of the checks..
make sure you have selected all Sheets to print.. there's a possibility that you have selected some views.
Someone with the similar issue would help you here.
Try printing those sheets individually. worst case scenario.
Best luck.
Corsten
Building Designer
