Bulk Edit Parameter Value
5 ANTWORTEN 5
Nachricht 1 von 6
ppumGBNPS
376 Aufrufe, 5 Antworten
Hi, Im trying to edit all of the manufacture parameter of my window family as they are all from the same manufacture. I have been editing the manufacture parameter value of each window one by one. Im wondering if there is a way to bulk edit the parameter value all at once? Also ive tried the oneparameter from the diroots plugin but for some reason the value remain unchanged.
5 ANTWORTEN 5
Nachricht 2 von 6
L.Maas
als Antwort auf: ppumGBNPS
Where are those families, inside your project, or in your library on your computer?
in both cases it can be solved by a Dynamo script. When the families are in a folder on your computer the script gets more complicated
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 6
vitorbortoncello
Did you follow this tutorial?
https://docs.dirootsone.diroots.com/docs/pages/OneParameter/OP-OneParameter.html#:~:text=OneParamete....
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 4 von 6
We do this quite often in Projects through a Schedule to change Identity Data primarily.  It's pretty painless and easy.   Maybe the better solution would be to leave the source/original Families as they are, and modify those only those Families that are actually loaded and used in Projects.
BTW: you can always save a copy of all the Families in a Project via Save As => Library.
Nachricht 5 von 6
Create a schedule, unitemize so the windows grouped into one row, then enter the parameter value.
Nachricht 6 von 6
handjonathan
Hi @ppumGBNPS
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @L.Maas @vitorbortoncello @barthbradley @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
