99% of the data I get out from buildingbook is useless for me, I only need very specific numbers. Ideally, would be great if I could amend it to follow a certain form as well..
-I use buildingbook only because I need the German calculation method to be used, which not aparently possible directly in revit.
thanks!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
what do you mean by specific numbers you mean being rounded within revit ?
