building pads changes topography
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
Pantaleon02
984 Aufrufe, 4 Antworten
Hello :leicht_lächelndes_Gesicht:
I made a topography surface using a cad file (DWG) and now when i'm trying to add a building pad to it, the topography changes...
I'm kinda new to revit so i'm not sure what to do...
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Pantaleon02
I think that's how it is supposed to be doing.
Nachricht 3 von 5
Pantaleon02
als Antwort auf: ToanDN
well i'm following a revit course/ training... and I have an image for reference and the topography looks fine there, but not when i'm trying to do it... :verwirrtes_Gesicht:
You can see in the image below... maybe it's something wrong that i'm doing?
Nachricht 4 von 5
RDAOU
@Pantaleon02
Try to check the Site settings and adjust the intervals at which the contour lines are displayed and the increments
Nachricht 5 von 5
Pantaleon02
als Antwort auf: RDAOU
The first thing i did was check the Site settings... :leicht_lächelndes_Gesicht:
I found a workaround, i just edited the toposurface by adding missing points...
not sure if that's the actual solution but it worked.
Thank you guys for answering :leicht_lächelndes_Gesicht:
