BUILDING PAD PROBLEM
Hi, i have a problem with a building pad showing throght the concrete foundation.
  How can i fix it?
Here is an image with an example.^93568617F7EC2CAE3CF5C0E0FC31A2A972A0CA99BAD039239A^pimgpsh_fullsize_distr.jpg
Thanks.
FGPerraudin
Hi wolverine,
Revit is not that good at site building...
So here is what I personnaly do.
Hide the pad in your view and everything will be fine!
It just rests on the idea that you build a pad AND a floor for the slab...
So  I build a pad that has a negligeable thickness, so that it doesn't conflict with the rest. As a material, I use the same as the site...
Hope the trick works for you,
Cheers,
François
Francois-Gabriel Perraudin
BIM management and coaching
Thanks Francois, it did works. thanks for the idea very much.
FGPerraudin
No worries, it is a pleasure to help!
Thx,
François
