Building PAD at diferents elevations
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
agustinbarovero
627 Aufrufe, 3 Antworten
Hi, I need to generate an excavation at different stages in Revit. I need to go climbing first at a depth of 3m and then go down to 7m.
I try to do it with building pad but it can't overlap. I would like to know ¿How  can I do it?
Tags (2)
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: agustinbarovero
The -3m pad should be created in phase 1, demolished in phase 2. The -7m pad should be created in phase 2. They should share the same sketch boundary.
Nachricht 3 von 4
Can you elaborate? What do mean by "stages" , "climbing", "overlapping"?
Illustrations might help.
Nachricht 4 von 4
agustinbarovero
als Antwort auf: ToanDN
The problem it was in the phase of demolished.
Thank for your time.
