Building Elevations changing
12 ANTWORTEN 12
Nachricht 1 von 13
batied
1059 Aufrufe, 12 Antworten
After the installation of the site contours the building levels changed from first floor 0'-0" to -106'-0"  The Project Base Point is set at 106'-0"  The Contour Labels Elevation Base is set at Survey Point.  Site Elevation points were created as negative feet below 0"-0".  Example 103 = -3'
This is a class exercise that I have used for 10 years and this is the first time this has happened.  Two students have had the problem.  We are using Revit 2020.
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: batied
Not following.  What do you mean by "installation of site contours"?  Also, if your Level is reading negative 106' -0", and the Level is relative to the Project Base Point, then the Project Base Point Origin is 106' - 0" ABOVE the Level.
Nachricht 3 von 13
syman2000
Post up the file so we can take a look.
Nachricht 4 von 13
_Vijay
yes, it's kind of strange. if you show some images it will be better clarify for assisting.
Nachricht 5 von 13
batied
als Antwort auf: syman2000
Attached is the student project and my project.  Note the differences in the levels.  They are the same difference, but obviously different.
David
Nachricht 6 von 13
batied
Here are my project and my student project.  Note the differences in the levels.
David Batie
Nachricht 7 von 13
batied
als Antwort auf: barthbradley
Batie, David L has shared OneDrive for Business files with you. To view them, click the links below.
[https://r1.res.office365.com/owa/prem/images/dc-generic_20.png]
Student - FINAL PROJECT.rvt
BATIE - FINAL PROJECT 005.rvt
Attached are my final project example and my student's project. Note the differences in the levels.
David
Nachricht 8 von 13
Here's what is going on between the two projects. See attached screenshots.
Nachricht 9 von 13
Nachricht 10 von 13
batied
I see the difference but how do I fix the student’s model to look like mine. I do not see differences when looking at the Survey Point Internal.
Nachricht 11 von 13
Well, if you don't want to move the PBP and SP, then change the Levels' Elevation Base in one of the Projects. Project Base Point to Survey Point, or vice versa.
Nachricht 12 von 13
Nachricht 13 von 13
Move you student's model Project base Point and Survey point 106' down.  File attached.
