building bad
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
omarqassem94
334 Aufrufe, 1 Antwort
building bad
Hi
Is the building bad replace the floor in the GF and if its
where i shod placement the building bad ??
on the edge of the walls
or
on after the brick inside the wall so the wall and the bad dosent overlap and mess up the 3d view and render
Tags (1)
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: omarqassem94
You could use a building pad as a slab on grade.
But I would have both, a building pad as the site preparation slab (can be concrete, gravel, sand, compacted earth, or a combination); and separate building slabs of reinforced concrete.
