I have modelled a turnbuckle rod family. The family has a nested line-based turnbuckle rod. Flexing the X Y values in the family editor behaves correctly. Flexing and changing the type inside the project demonstrates that the rod ignores the values. See attached project which demonstrates the problem.
Gelöst! Gehe zur Lösung
Gelöst von azad.Nanva. Gehe zur Lösung
@ToanDNit's definitely a bug / problem with Revit .
I made a tiny minimal demo project of the glitch. See attached.
When a nested line-based family is set to obtain it's length parameter from an outer family parameter ( the problem occurs with either a type-based or instance-based length parameter) the nested length is not adjusted correctly.
The demo project shows the outer family with a dimension set to 8'-0 and the geometry stuck at 4'-0.
Inside the family editor, the line based nested family behaves correctly. Only when loaded in the project does the problem manifest.
you create Family the Line Base.rft.
You just need a lock.
this is an internal Revit problem over calculate which one first.your family calculate the Angle but not Length so fast.
I change your family :
and this is your file:
