Bug revit 2021
3 ANTWORTEN 3
Nachricht 1 von 4
GHASEM_ARIYANI
353 Aufrufe, 3 Antworten
Bug revit 2021
Hi everyone
It has happened many times since the day I installed version 2021 During the project, the model stops.
It's like it's locked. It restarts after a few minutes. It even happened in a small file. This happened on two different computers.
Has anyone had a similar problem so far?
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: GHASEM_ARIYANI
Nachricht 3 von 4
GHASEM_ARIYANI
als Antwort auf: barthbradley
Hello @barthbradley
I think your answer has nothing to do with my problem. I don't have any plugins right now
Tags (1)
Nachricht 4 von 4
Sometimes it does relate. Sometimes it doesn't.
If you really think it's a "BUG", you ought to contact Autodesk directly.
