When a spline is drawn in the split face command to split a floor into multiple zones, the spline CVs are no longer editable upon accepting the sketch. They cannot be selected when tabbing into them the way they could be used when drawing the sketch.
@barthbradley wrote:I seem to be able to add control points. 2020.2.30.42
In that case I'll have a look at 2021 to see if the issue is present there. May take some time, since my PC is broken atm.
Bug reports go elsewhere.
Here's what happens on my end:
I can modify the spline endpoints but not the CVs that are in between.
Furthermore, non-planar faces cannot be split, but I expect that to be a known limitation.
Please see message #4.
